Mopar headlight switch
ijg4503
Peachtree City, GA
For sale is a new Mopar headlight switch (aftermarket). Headlight switch for 1960s-1970 models. A similar part sells new from YearOne for $39.95.
Headlamp switch w/panel dimmer
This is a new high-quality headlamp switch for most muscle-era Mopar cars and trucks with the typical "pull for headlights, rotate left to dim panel lamps, rotate more for dome lamp" setup. Made in USA by Chrysler's original OEM manufacturer to correct HD factory specifications. This is the premium, heavy-duty version, with the high-capacity rheostat that won't overheat and burn out, and the 25 Amp internal self-resetting circuit breaker so it can be used on 2 or 4-headlamp cars without incurring overcurrent shutdown "on-off-on" problems. Please compare your current part to the picture of the part that I have provided to ensure they are similar. (female threads on front of switch, triangular knob shaft)
$20.00 + shipping.
Thanks,
Jason =P~
770-990-8529
[email protected]
