swing69
fightin' socialism
Here is the "package" I am offering for sale. This is a 73+, LBP disk brake set up for an A body. Pick up in central NJ only, no shipping. All parts have been degreased, blasted and painted unless otherwise stated.
73+ UCAs, tight ball joints, new bushings (locktite green and tacked)
73+ Spindles (10.87 brackets) and all spindle hardware with 4 new non-oem LBJ/spindle bolts
73+ OEM rotors, machined, .960 thickness (.940 min.)
73+ Reman. Calipers , with hardware and good used pads (clean)
73+ New hoses.
73+ repacked bearings
73+ UCA Eccentric adjusters (4)
73+ Prop. Valve (as removed - dirty)
73+ Caliper banjo bolts and new washers.
73+ Shields with bolts.
You will need: 73 drum/disk master cylinder (any auto parts store) and to clean/service prop. valve.
All parts as-is, no warranties, no claims - they are "used" parts.......Pick up buyer rec. preference, I prefer NOT to ship. I'm in Central NJ, near the TPK.
$375
73+ New hoses.
$375
