Mopar Low Oil Pressure Switch
71-440-Duster
Northern Cal
Guys,
I have purchased the mopar low oil pressure switch to install in my Duster, but I would like to know the best way to install it. It didn't come with any instructions. The part number for the switch is p4120223.
Thanks in advance...
Rob
If I recall correctly;
a wire goes from the sender to the positive side of the coil,
and grounds the ignition,
in case of low oil pressure.
It also will not let the engine start till the oil pressure
builds up to at least 15 lbs, if I recall.
I bought one of those in 1979, not sure if it is in the cave
{cellar}. LOL.
