Mopar perf. Camshaft Identification
Slappy
Tampa Fla.
Thanks to all whom can help. I recently aquired a built smallblock 360. I was told the camshaft was a purple camshaft. It is purple in color by the way. They lost the ID card. I am ot sure whats in the block. I have torn down the short block for inspection purposes. The only number I can find stamped on the shaft is at the distributor end. This is the number 940163. This number doesnt cross to anything in jegs or summit. Can anyone identify or give me some direction into finding out? Thanks.
That's probably just a serial number. The only way I have ever been able to identify Mopar cams is to measure the lobe lift and match it up to a purple cam. Can you measure the lobe lift and post it? I can probably help then.
