[SOLD] Mopar Performance 360 Cast 4.0" Stroker Crank – Used
Rocket
CT
I have a nice used Mopar HD 4.0 stroke, 360 main, cast crankshaft part number P5007258. Crankshaft is in nice used shape and was new when installed in a bracket car. Journals are standard dimensions. Some deburring was performed on the throws and other areas as you can see in some of the photos. This crankshaft was used for two seasons and have gone another direction. Crank shows some typical marking for being used. Most marks are not able to be felt with a fingernail. A couple you can slightly feel it.
Price is $275 plus shipping.
I have the same rods as used but a new set. They are in a different add. Eagle H-Beam. The used rods were sold. I have the used pistons as well. They are KB 744 30 oversized
How much for the crank and pistons together shipped to 30043? Thx
Compression with a flat top piston with 6.6 cc valve reliefs, 62 cc chambers, 0.040" gasket with 0.00 deck height is ~ 11.8.
I also have the damper for the crankshaft for an extra fee. Removable weight so it can be retained for use with an externally balanced assembly or removed for use with an internally balanced assembly. Summit part # SUM-B64278.
