Swingin1970
Mopar Perfomance Aluminum 742 case ($1,100 case)
Strange 35 Spline Lightweight Spool
Richmond 4.30 gear set
Strange billet 1350 Yoke
Only 2 Seasons on drop out (70 Passes).
Located in North San Diego
$1600.00 weighs 51.5 lbs
Designed to reduce weight and hold up under high torque. Uses 1-3/4-inch large stem pinion and standard components. The 8-3/4-inch aluminum axle housing uses "742-style" large stem ring and pinions and fits 8-3/4-inch banjo housings (up to 1974). It features a weight reduction of 44% (approximately 11 lbs. to 14 lbs.), compared to production cast iron housing, and includes 6061 billet aluminum caps. It is stiffer than cast iron, and decreases pinion deflection by 10%.
