[SOLD] Mopar performance A body super stock Springs 002/003
Bigboy 68
it is what it is
Legendary Member
Middletown, Delaware
Rating - 85.7%
24   4   0
I have a like-new set of P 3412002/003 super stock Springs they were on a car for less than 500 miles didn't like the stance wanted something to raise the back end up more
Asking $200 and I can bring them to Carlisle if paid in advance otherwise shipping is on you PM me if interested
The bushings are all good ready to bolt on and go
I got a Squatted down '65 cuda with Four Springs each side...
Is it pretty simple to convert the Smaller Size Springs Mounts to the Larger SS Spring?
Yes as far as I know it is it's my understanding you just need to get the larger 5/8 spring brackets for the front they have a 5/8 bolt hole
Maybe I could just Drill the Stock One's...
Easy Enough! Hell, I'll send you a PM in just a minute...
I wanna get some of the Squat out of this car, Do you think your Springs will raise it up a bit?
They add a lot of height over stock, I have them in my 66 but I like the tall height, but keep in mind they are for drag racing and they are stiff on the street....they are different side to side also and when installed properly the car sits higher on one side, this is designed to help launch and traction. I’m not sure you want to drill your old mounts out, it will weaken them, infact they may not work at all, just buy the correct hangers and hardware. But I like them on my 66 and work good
I'm good with that... I have an Air-Shock on the Right Side and Traction Bars now for the Look and I like a stiffer ride anyway...
