Mopar Performance dual plane dual carb intake for 6.1
biff426
New Member
Delaware
I am curious if anyone has used the P5155462 mopar performance intake and if so what results. I am torn between the modman and this intake the dual plane part concerns me I am doing a 426 4.080x4.080 6.1 with good flowing 6.1 heads 11.1 comp and still figuring out the cam. I want to do a dual carb setup and like the looks of the long runners on the Mopar perf intake.
If it's the intake I am thinking of its nothing more than an Eddy dual plane and I used it for early 5.7L heads. Mopar Perf may have made a run for the larger 6.1L ports but I don't know. I had the 5.7L version on my car with 2 500cfm Eddy/Carter carbs. It's before I changed my hood and intake setup so the weight was 3775lbs with driver, stock cube 5.7L with work. Ran [email protected]
