Mopar Performance Fuel Injection System
JGC403
Baileyton, TN
Will the Mopar Performance fuel injection kit P5153339 work on the Eagle 5.7 or a 6.1 Hemi?
I like that the Mopar Performance Kit doesn't use the drive by wire for the throttle body.
Been thinking of doing a Hemi swap into my '76 Duster, so I'm trying to compile a list of everything I need to do the swap, so been reading a lot.
Highlight your part number, copy it and paste it in the Google search window. Plenty to read about it there.
It will operate an early 5.7 (without MDS) , a 6.1 and the MP 392 crate motor. Requires a cable driven throttle body. I have this system, still new in the box for my 6.1 stroker 392. I bought it when nothing else was available. I prefer throttle by wire and am thinking seriously of selling my current system for the Holley system.
BTW, you could probably run it on an Eagle 5.7 if you lock the VVT and replace the MDS lifters with non MDS.
PM me if interested in buying my MP ECM and MP throttle body.
Are you able to tune the PCM in that kit, P5153339? I seen it mentioned somewhere that it wasn't, but can't seem to find anything else to back it up.
Is there an aftermarket PCM that is capable of using the Eagle Hemi's VVT or does it have to be locked out no matter what PCM is used?
My ECM is fully programmable. I'll have to go check the part number and make sure we're talking about the same piece.
