[FOR SALE] Mopar Performance MPFI single plane intake P4532731?
NoCar340
The Original Partstitute
Upper Peninsula MI
This is an M1 intake for Magnum heads with an LA-style water outlet. I believe it's part number P4532731; casting number is P4532587 was used for multiple final-machined versions. Dual-pattern flange accepts Holley 4150-style throttle bodies. This is very similar to the MP 360 Magnum crate motor intake (it also bears a striking resemblance to a Strip Dominator), except it's natively drilled for fuel injectors. It can be modified to fit LA heads. No porting or other modifications, all threads are good. This is the intake only; I don't have anything else. It's exactly how I got it, white paint and all. If you want to see more or specific pictures, just ask and I'll take them.
$500 + shipping from ZIP code 54151. If you're in MI, eastern WI, or northern IL/IN/OH, inquire about potential free shipping.
I do not accept online payments. Personal/bank check, money order, or cash if you're local... or banzai enough to mail it.
