[FOR SALE] Mopar Performance Parts
DART5770
Albert Lea, MN
*Meizere water pump block off plate for small block Mopar. Used for 1 dyno session. Black. Part #WP115S. $50
*New electronic distributor for B.B. Mopar RB 413-440. Factory style with vacuum advance. $125
*New Manley 221424-16 Nextex 1.640" roller valve springs. 250#@2.00", 800#@1.150". New in the box. $240
*Freshly ground B.B.Mopar 383 forged crankshaft, ground and crack checked by Crankshaft Supply Co MPLS, MN. .010"-.010". Has some minor staining on journals from sitting, but no effect on use. Has been re-polished. $140
*New ARP head bolt kit for B.B. Mopar with Edelbrock Victor heads. Arp #145-3609. $105 new, sell for $65.
*New Wilson 1" light-weight, taper bore carb spacer for 4150 carb. #004110. $143 new, Take $100 for it.
*Used Comp Cam electric vacuum pump kit with vacuum canister, missing some wiring, but major stuff is there...relays, etc. $150
*New/used Lower adjustable coil-over shock brackets - No hardware. Adjustable rear end housing brackets are new and shock brackets that bolt to them are used. As-is $35
*Used set of 10 degree Titanium retainers for 1.55" dual valve springs (with free set of used springs-if you want them) $50
*Used Cam Dynamics roller cam for S.B.Mopar. Grind #CD278/284RA. 278*-284* dur @ .050", .620-.640 lift. 106* lobe seperation. Original lash .035"-.030", but ran it alittle tighter @.026"-.028". One lobe marked up a bit, but have run since with no issues. as-is. $100
Rebuilt Holley 3310-3 750cfm vacuum secondary carb. No choke, Quick-change secondary spring cover, newer base plate,and new accelerator pump arm. Stock jetting-73, power valve 6.5 and squirter-25 with yellow secondary spring(lite). $185
*New Manley head bolt kit for B.B.Mopar with 440-1 Indy heads, #42198 for (2) heads $50
*New Hughes 2000 stall converter for 727 Torqueflite #24-20. (shipping can be expensive on these) $250 *********SOLD***********
*Used Mopar Performance constant output voltage regulator - part #P3690732 $10
*Used Serpentine pulleys for S.B.Mopar. 3 piece, black - Alternator, Crank, and Water pump. $50 Nice condition. *********SOLD*********
*Used IHRA 'Crate Motor' short block. 360 - 300hp S.B.Mopar. .030" over, filled block, factory crank and rods with ARP bolts, Sealed Power Hypereutectic pistons - flat tops with 2 eyebrows, back cut rings. Block, crank, rods and pistons only. Nothing fancy, but set an IHRA national record at one time. Needs freshening, been sittting awhile. $500
All parts are plus actual shipping costs.
Call *** *** xxxx days or PM
Please no tire kickers, dead beats, or wanna bes. I'll take your Paypal, but I won't wait for your promised money order. And please don't ask- I will not ship for free. Any other questions please call. You will get faster results as I am not the computer 24 hours a day! I do have more pix if needed.
I will take the Hughes Convertor for a 727. Please send me a shipping quote to VA - Zip 22611. I can send payment via paypal. Thanks and look forward to hearing from you.
