Mgc340
Reposting this due to a buyer not paying or following through. Cash only people. I won’t hold anything. I won’t respond to generic comments like still available, more pics etc. serious inquires only.
59’ Mopar R block
Tall deck 9.56 deck height
Fresh bore 4.065
New cam bearings
4 bolt main caps
Block is clearanced for big stroke crank
ARP main studs
Ready to run!
$3,500
W5 first gen heads cnc ported @ SDSS
2.08/1.70 valves
Conservatively ported no epoxy!
1.6 Harland sharp rocker arms
Indy intake with 4500 adapter
ARP head studs
Fresh valve job
Roller lifters
Bullet roller cam 712/720lift 302/308 dur
$4,500
BPE 4.250 stroke crank
340 mains Chevy dimension rod journals
Callies Compstar Rods 6.200
$1,000 for rods and crank
I don’t have pistons, all that’s needs is a set of custom pistons for 4.065 bore.
This will make over 440 cubes on a small block!!!
Or
$8,300 for it all!
59’ Mopar R block
Fresh bore 4.065
New cam bearings
4 bolt main caps
ARP main studs
Ready to run!
$3,500
2.08/1.70 valves
ARP head studs
Fresh valve job
Roller lifters
$4,500
Or
$8,300 for it all!
