MOPAR Race & Street Performance Parts: Whats Left.
DART5770
Albert Lea, MN
MOPAR Race & Street Performance Parts: Update on parts left and some new additions.
*NEW Hoosier 28-4.50x 15 drag race front tires. (2) (reg $155 each). $250 for the pair!
*Holley Strip Dominator. SB Mopar W-2 head oval port intake manifold. $175
*Pair BB Mopar '346' head castings with OE stock valves. Same as '906' or '452' heads. Milled approx .080" - 78cc chambers. Approximately 10 cc's smaller than stock and comparable to 915 closed chamber heads. Fresh, but older valve job. Could use 2 seats. AS-IS $250 OR with ALL NEW
Bronze guides, 2 seats installed and fresh multi-angle valve job and springs, retainers, & positive seals completely assembled with tip height and
spring installed height set. *****$695.
*Milodon deep pan and pickup for 360 or Magnum engines - cars. #30940 & 18345. 8 qt. 8-3/4" deep.
Some modifications. $185
*Factory 426 Hemi rods, used, singles. $50 each.
*426 Hemi race pistons, singles, Venolia & TRW 4.280" bore. $25 each.
*MANTON 3/8" heavy wall pushrods for 440 with hydraulic cam and adjustable rockers. $125
*NEW Elgin 3/8" chrome moly pushrods for 383-400 with hydraulic cam. $75
*VDO 9000 RPM Play-Back tach with shift lite and instuctions. $160
*NEW Mickey Thompson 28.0 x 7.5 - 15 Sportsman front tires. pr. $240
*340 +.030" forged pistons, Full dome 12.5:1 compression. Litened and gas ported by Patterson
Racing. For .990" wrist pins. (not included) $250
*SB Mopar head stud kit $60
*NEW Hyper-Coil coil over springs 14" x 2-1/2" 300# $100 pr
*Power glide Aluminum trans shield for deep pan. Good condition - SFI expired. $50
*NEW Mopar Performance 3.9 V6 Head gaskets. $10 pr
*Biondo Racing Air cylinder throttle stop/ throttle controller with air cylinder, solenoid, and CO2 tank and regulators. $125
($259 New)
*NEW 727-904 Torque-flite 5.0 Ratio band apply rocker *****$25
*NEW Mopar Performance Leaf Spring Perches. In the box. *****$15
*Barry Grant 1/2" 4-hole wood spacer for 4500 Dominator carbs. *****$20
*Used K & R Delay Box - - Early Model - - Model XTC-200 with Throttle stop, Delay & Cross-over. Works!! *****$50
*NEW Chrome Small Block Mopar Chrome Valve Covers *****$30 pair.
*RIMAC 1000# valve spring tester, very nice condition. ****$450
* Rebuilt MOPAR B-Body A-833 23 spline, 4 speed transmission. Trans has: NEW Input bearing, NEW front bearing retainer and seal, NEW rear bearing, NEW extension housing bushing and seal, NEW cluster shaft and input needle bearings, NEW Syncronizers (4), NEW cluster gear thrust washers. Clustershaft like new. Synchronizer teeth on main gears and sliders in acceptional condition for 43 years old. Cases hot tanked, blasted and painted. Front bearing retainer is 4.805" diameter to fit 68 up B-body (most popular) or can be turned down to the 4.354" for early B-body bellhousing. .........$750. outright.
Original 4 speed for 1967 Satellite 440 car. Casting numbers: Main case C-97372 date 5-23-66, Tail housing C-96707J date 5-17-66, Transmission stamp date plate 8-5-66
Realize its not for an A-body, but maybe someone can pass it on.
*FOR SALE: Brand NEW 1995 Dodge Dakota 2 wheel drive Standard cab, Short box BARE Frame. NO suspension pieces! Should fit '87-'96 Dakota or well suited for Street Rod, Resto-Mod, etc front frame section swap as this set up for factory rack and pinion steering and double A-Arms. 1987-1991? had 5 lug wheels & disc brakes. Front section could be grafted under about any project, just as Camaro & Nova front stubs are used. Gotta GO! ****$100**** Compare to salvage yards that want $600-$800 for a used frame!!
*Used MSD 6T ignition sytem. Same as 6A box, but for heavy duty, or high vibration usage. Hasn't been used since rebuilt from MSD. Carried as spare ...$120
PM or 507-373-5907
Can supply more pictures of interested parts, but may take 24 -48 hours. Please be patient.
Parts can be shipped by UPS or USPS at actual cost.
Cash, Money orders, Pay-Pal or ?
***ALSO LOOKING FOR 6.1 HEMI PARTS******
