Mopar SB Cam Bearing Installer Tool
Found mine at the local tool house. On the shelf just waiting for me.
Thats one of the special tools that I dont know a way around.
Good hunting
and make sure you get the oil holes positioned correct.
Mu first time useing it a screwed up a couple of bearings. I went to the store for another set and got it right. Easy to use, easy to screw up.
I'd recomend 2 set of bearings.
1 to practice practice pratice on and the 2nd to do right by.
usually the machine shop installs those. it's cheaper then the second set of bearings. if you really want to do it yourself, harbor freight usually carries one, otherwise try a real auto parts store, they can probably order one. (or a tool truck) expect to pay 100-150 or more for one. Doug
I rented one and did my own. The machine shop only charged my son $20 to do his, it cost me more than that to rent one. I'd check w/local machine shop. My .02
