streetkit
OEM Factory Mopar Small Block 273, 318, 340, and 360 4BBL kickdown linkage assembly. It is a complete assembly with the 4bbl throttle bracket, the rods, springs and the pivot cranks. This unit came off a 1979 Dodge Aspen R/T that was a factory 318 4bbl car. Very similar to the earlier linkages except that the adjustment is made down by the trans instead of up by the carb. If you are converting your 273, 318, 0r 360 from a 2BBL to a 4BBL, you will need this part.
$95 shipped to your door anywhere in the USA
