[SOLD] Mopar Small Block Bell Housing 2892482 1969 date coded
jtkaaa07
BossMan
Neenah Wisconsin
10.5" small block bell housing cast #2892482. 4.354 bearing retainer diameter, bell housing has no cracks or damage of any kind, threads checked and chased with tap, bead blasted, and painted with cast coat aluminum. Uses 130 tooth flywheel. Includes appropriate fork pivot bracket and correct clutch fork. Absolutely awesome condition, and ready to install! As stated this bell housing has a 1969 date code. Asking $275 plus the ride, located in Central Wisconsin
Thanks Jeff
