jtkaaa07
BossMan
Deal fell through so listing again.10.5" small block bell housing cast #2892482. 4.354 bearing retainer diameter, bell housing has no cracks or damage of any kind, threads checked and chased with tap, bead blasted, and painted with cast coat aluminum. Uses 130 tooth flywheel. Includes appropriate fork pivot bracket and correct clutch fork. Absolutely awesome condition, and ready to install! As stated this bell housing has a 1969 date code. Asking $250 plus the ride, located in Central Wisconsin
Thanks Jeff
Thanks Jeff
