joes68340s
Has anyone installed one of these. it uses three bolts, is there anything special to do when installing on a 340. Thanks
Captainkirk said:To keep your cam timing "on" while decellerating (engine braking). Sometimes hi-lift cams can cause the valves and piston to miss by a whisker....that backlash can eat up that whisker. There may be other reasons, too that I'm not aware of.
keelhaul21 said:A quick question, how do you know if a timing chain has stretched?
To see how they can get, click my thread here and scroll down on the first page to near the bottom.keelhaul21 said:A quick question, how do you know if a timing chain has stretched?
65s said:So I'm sitting here reading this thread, knowing my cam chain is really worn and I need to replace it. What timing chain should I buy? It's a generic 273 commando clone (273 commando intake on it with carb and dress up parts). Should I install an tensioner or is that only for racing applications or 340 applications?
