bbeep71
I've looked at many articles for early disc swap and have some questions.
1. Car is 1966 barracuda V8(360) with 10" drums all around with dual M/C conversion
2. Parts are from 1975 dart 6cy. with manual disc brakes(1 piston slider)
3. I know upper control arm is replaced(big ball joint) and 75 spindles need 75 lower ball joints.
QUESTIONS
1. Some say don't relieve tension on torsion bars. Some say just relieve tension on torsion bars and others say relieve tension and move bars back a few inches. What is correct?
2. Will the stock 66 suspension tie rods connect to the new 75 lower ball joints or do I need 75 tie rod ends?
3. Will the M/C push rod now being used for the dual M/C be correct for new disc/drum M/C?
4. Do I need special disc brake 14" rims to fit the new brake setup?
Please advise
QUESTIONS
Please advise
