[FOR SALE] More misc parts for sale
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
I'm cleaning up around here and need to sell a lot of parts I have collected. Don't see it ask for it I may have it. I have a bunch of the everyday parts, to many. I spent all day taking parts out of storage and trying to categorize them to lest them on different for sale forums. This is a bunch of Mechanical parts for sale. I will try my best to combine shipping where possible to save on costs. Feel free to make me a counter offer if you feel I'm to high. all items do not include shipping. Thanks
1) UCA cam bolts $2.00 ea
2) Manual brake master cylinder rod $30.00 each 1 left, SOLD one.
3) LCA pivot pins $10.00 each
4) A-body rear upper shock pins. $10.00 each
5) BB distributor/oil pump drives $10.00 each ( sorry you can barely see then at the top)
6) 7260 29 spline Yoke. $40.00
7) 7260 10 spline Yokes $40.00 each
8) 7290 10 spline Yokes $50.00 each
9) sold
10) Speedometer drive housing,29 tooth gear, bolt and clamp $25.00
11) SB Fuel pumps (good) $5.00
12) 1968 and newer A-body battery tray and brace $25.00
13) 1972 and newer A-body charcoal canister mounting bracket $25.00
14) New SB 1970 and newer aluminum water pump $20.00
15) Pinion snubber off A-body 8 3/4 was on my 68 Barracuda cleaned and painted $25.00
16) Harmonic balancer 400 cast crank $15.00
17) harmonic balancer 383 steel crank ( really good condition) $25.00
18) Harmonic balancer 360 external balanced off my 360 Dart $25.00
19) Rear axle seals, 8695s for 8 3/4 3 of them $5.00 each buy all thre and Ill include 4 flange gaskets. SOLD!
20) 727 BB Inspection cover $25.00
21) Various fan spacers 1" to 2 1/2" $10.00 each
22) Single SB water pump pulley 6 1/2" diameter, 2 3/4" tall $25.00
23) Misc pulleys, your choice $10.00 each
re posting pictures.
I added an evap can system to my 71, do you know what diameter cannister your braces would fit?
I don't have the measurement, But I know for fact the dark one came off a 71-72 A-body. If that doesn't help, Let me know and I'll measure them.
terrific
ill run out and measure mine as well (right now it is attached with a set of hose clamps)
9) sold
PM sent
