more on the one pc. pan gasket.
RPM
Superior Member
Meridian, Idaho
ok. the 1 pc pan gasket for the 360 looks like a sweet deal.
However, it is a real pain.
It would be a great deal if the motor was on a engine rotisserie and you could just slap it on. Not so great when the motor is still in the car.
you have to install the gasket to the block, not the pan. I used some high tack spray and fought that sucker for a hour before slingng it accross the shop. I thinks I will try my hand at the original set up, unless someone knows a slick trick to install that sucker better. Yeesh.....my kingdom for a hoist in the shop!!
-RPM
