More trim questions?? Delete trim or not???
carcrazyguy
Amarillo, TX
Sorry for another question.
Anyway the Dart is now heartless (motor and trans out), bottom of the car has been cleaned (spent three days laying on back with a pressure washer and a scrub brush), and the window jams have been sprayed and the glass is ready to go back in. Now that I took the car back to the bodyshop I need to decide on the mouldings. What to leave on and what to fill. I removed the vinyl top trim and the holes were welded up. I am also having the trim on the top of the doors removed. But the car had the lower trim below the door the goes from the front wheel opening and curves down just in front of the the rear wheel opening. The car is FE5 and had the lower area below that trim black from the factory. I am thinking it would look better all red(no trim at all there)?????
