[SOLD] Morison electric water pump
kingvern
Clarksville, Michigan
Description: Moroso billet aluminum OEM mount electric water pumps move up to 21 percent more coolant through the system than any competing pump. They mount in the stock location with stainless steel mounting hardware and work with both 12V and 16V systems. They feature a billet aluminum pump housing and impeller, heavy-duty windings, long-life brushes, a stainless steel shaft, sealed ball bearings, a blue powdercoated outer case, and a high-temperature Viton® seal. They're available for a variety of engines. Also comes with the 1 3/4 hose fitting. Used it for half last summer. Still looks brand new. 275.00 +actual shipping.
