[SOLD] Moroso #64700 aluminum crank pulley
physixx
Edison, NJ
I have for sale a gently use Moroso #64700 aluminum crank pulley that was on a 360 Bracket engine. It has the offset attaching bolt positions (pre 1972), measures 5” overall diameter and 2 ¼” deep.
Moroso Cast Aluminum Crankshaft Pulleys 64700
Even though this pulley has the one offset bolt and aren't all equally spaced, it can still be used if you put 4 attaching bolts opposite each other on the equally spaced bolt holes. Works fine. This pulley is in excellent shape and comes with the 6 allen head bolts that attaches it to the balancer. I would like to get $40 plus shipping for everything.
Ken
Edison. NJ
