[SOLD] Moroso SB Billet Electric Water Pump
Valiant1
Redford, MI
For sale is a Moroso Electric water pump P/N 63565 for SB Mopar. Very little use and in excellent condition. Comes with mounting bolts, alternator spacers, and the radiator hose fitting (which is sold separately for $30). You will need a gasket. This sells at Jegs for $335 (not including the rad hose fitting). I'm asking $200 + shipping. Located near Detroit. PayPal only.
Billet Pump Features
•Low amp draw
•Compatible with 12-volt & 16-volt systems
•High-temperature Viton seal prevents leaks
•Requires hose adapters (-16AN inlets except big block Chrysler)
•Each pump plate has been revised to remove unnecessary weight
•Mounts to stock location (gasket & stainless steel hardware included)
•Easily accommodates lower radiator hose from driver or passenger side
•Drive belt and fan eliminated to minimize weight and optimize horsepower
•Average overall pump height shortened by 3/4'' and weight reduced up to 2 pounds
•Flows up to 21% more water through system than competitor pumps (varies from 30-37 gpm)
•Maximum circulation improves cooling efficiency during all driving conditions, especially when idling
•Electric motor with heavy-duty windings, stainless steel shaft, sealed ball bearings, and long-life brushes
•Clear anodized 6061-T6 aluminum housing, plate, impeller, and motor cap with black powder coated outer case for reliable rust-free use
