Motor Mount change help
Plymouth65
Member
Lakeland Fl
I just removed a 360 out of a 77 Dodge truck and will install a 72 318. What I need to know is what motor mount brackets I use for the 318 to the truck.
Same ones from the 360 should work. There is a width difference between the 328 & the 360. Finding "proper" 318 mounts may prove difficult.
There is also Schumaucher creative services at engine-swaps.com
The right mount is the same for all small blocks, the left is different. You may be able to get away with putting 1/2" shims on the bolts to make up for the different with between the motor mount ears on the block...
The torque converter for the 360 won't work with the 318 as they are balanced differently.
