Motor mount orientation
scott657
Lancaster, Ca
the top picture are 273 mounts in a 64 barracuda
which is the driver side mount
the next pictures are of 318 engine mounts
Thank you
You have them oriented correctly in all your photos.....left mount=driver's side, right mount=passenger side.
thank you @cudamark
now the big Question, which mounts should I use to put the 318 into the 64 barracuda?
I also have no problem making modifications if necessary
Use the 273 brackets and rubber mounts. Depending on the year of your block, you may need to add an ear to the bracket(s) if you want to use all the bolts and block bosses.
I kind of figured that by the machining, but I probably would have asked anyway
thank you Mark
