Motor Mount Question
My72
New Member
illinois
I bought a 72 duster with a /6 and am putting a 318 from a 74 dart into it. The guy I bought the car from gave me a set of schumacher motor mounts but it says they are to convert from a /6 to 340 or 360. Can I use these on the 318. Not exactly sure what the difference is.
One side is a different width on the block. I think you will be ok with a bunch of washers? You'll have to go measure to be sure but that's where to look- the ears on the block
look here in transmission and drivetrain tech it may help although these mounts are not the conversion mounts --- Motor mount bracket difference - 318, 340
