Motor mounts?
The driverside bracket to the motor is differant. Just make a spacer or use a stck of washers.
Yes, you will need new mounts, the drivers side is different! But if you have two passanger side mounts from a 318 it will work, my father has a 67 Cuda that had a 318 in it and thats what I used to put a 340 in it!! Shumacker has mounts that you can buy, but the 318 mounts are a hole lot cheaper! hope this helps! :salut:
I replaced the 318 in my 73 scamp with a 360 and saved a boatload of $$$ on motor mounts with 3 washers.
