MP Magnum Cam Ques.
whitey
Andreas, Pa (near Allent
:?: I'm building a 360 Magnum engine for my 73 Swinger, I have a block, crank and rods, going to have the block punched .030 and decked, and follow the 300/360 cratre specs but use 9:1 Hyp pistons and the Magnum R/T heads, a Holley electric fuel pump and carb. I'm considering the R/T cam. The '02 MP catalog states that this cam is for MPI engines and noted that will not fit with mechanical fuel pump. Can anyone tell me if there would be a problem using this cam or stick with the 300/360 cam, and what about vacuum for power brakes? Thanks. :thumleft: 8)
