[SOLD] MP Magnum EFI Intake, Holley C950 MPI, Holley 950cfm tb
myduster360
North Mississippi
Selling the mpi setup off my Magnum 360, altogether or separate.
Paypal preferred
1) Mopar Performance EFI intake with throttle body adapter and 93 magnum fuel rail. This is identical to the 4bbl single plane intake 360 crate motors only it's drilled for injectors. It's one of the 1st they ever made and is setup for non-magnum water bypass but will work with a magnum pump too: $350+shipping
2) Holley 5.9L 52mm billet throttle body: flows >950mm and uses all the stock sensors and Cables. $100 shipped
3) Holley Commander 950 PRO ECU + MPI wiring harness + Lean Burn Distributor: $400 shipped(pics coming)
Everything $750+shipping
Commander 950 Software, Tuning manual and Base Maps can be downloaded here:
Tech Resources
I also have a 3rd party auto tune add-on, Pro 950 Auto-Tune, that will automatically dial in the VE map during Closed loop based on fuel trims.
I'm a Fuel Injection novice so I'm just trying to figure out if it's beyond my capabilities. I'm real interested but I'm an old dog trying to learn new tricks.
