its a 340 car though.Boy the factory was pretty optimistic about the little 318 with a 200 mph speedo. hahaha
Well ill find out when i get it on plates and can drive it around. Just waiting on some new tires from summit :þI would say that’s a KPH speedometer. I had a 65 Valiant KPH speedometer that readvup to 180 KPH - about 110 MPH. If this car was an export model to Iceland, then it would be correct
Yeah i think so. Its better for me to have a kph so i dont need to convert every time.That is most likely a Metric speedometer.
the fender tag might have the info if it is an export model.
Eather the fender tag is in a diffirannt place than normal or more likly it has been removed unfortunatlyPost a picture of the fender tag and we should be able to decode if the car was an export model.
