72Dart360
My timeslip shows MPH of 114.23 with ET of 11.372. 60 ft is 1.486. Should the MPH be higher? If so, what fixes it? My car weighs 3350 with driver, 3.91 rear gear, 904 trans with low gear set, 4200 stall.
What tire diameter do you have, and what rpm are you crissong the stripe at? Also - what brand and diameter of convertor are you running?
That sounds like a lot of convertor slip. I'm runnning 28" tire 3.91 gear @ 116MPH/ 5900rpm's275 60 15 Mickey Thompson drag radial. Crossing at 6250. The convertor is a 10 inch built by a neighbor.
My guess, a 10", 4200 stall converter is going to be pretty inefficient.
yes...
would be nice to see the other down track times....330...660...and so on
275/60 MT are 28 inch tall...with 3.91 gears....that is not alot of gearing for a small block
need info on camshaft...hydraulic...solid....as the engine might not want to rpm ..
what rpm is your 1- 2 and 2-3 shift?
fuel line...fuel pressure...fuel pump...
330= 4.49, 1/8= 7.11, mph=93.3, 1000= 9.40
ideal pass with a 11.37 et
60 foot 1.58
330 foot 4.57
660 foot 7.17
660 mph 94.74
1000 foot 9.44
1/4 mile et 11.37
shift at 6500...did you happen to see what the tach says going thru the traps..
1/4 mile mph 116.53
