[SOLD] MRL 408 Small Block For Sale
MRL Performance
here
Hey all. I know, its been a while since I have been on here. Its been a crazy year.
I have a engine up for sale. 360 stroker based on a Magnum block. Here are all the details.
360 Magnum block, oil passage drilled for LA style rocker oiling
M1 single plane intake
Aluminum fab valve covers
Comp Pro-Magnum roller rockers
Speed Master heads, CNC ported 2.08/1.60 valves
SCAT forged 4.00 stroker crank
SACT forged I beam rods
Icon forged dish pistons
ARP main/head studs
Lunati Voodoo solid roller cam 255/263 duration .584" NET lift
MRL/BAM roller lifters
Billet timing set w/tensioner
New front cover and water pump
Trick flow SFI damper
Melling high flow pump
Kevko 5qt oil pan
FiTech EFI system
MSD dist
Taylor wires
Champion plugs
Flame thrower coil
Pump gas 9.3 to 1 compression. 9-10 inches of vacuum at idle, 950-1000rpm. The FiTech worked real good, super easy to hook up and tune. We had fun with it, and its a nice system
It made 580+HP at 5800rpm with 500+HP from 4800rpm on up.
Torque was nice as well with 550+TQ from 5000-5300rpm and 500+TQ from 3850rpm to past 6000rpm.
It has a nice nasty sound, very responsive and pretty good driveability for the cam size. It would be at home on the track or the street, and is built to handle a power adder if you wanted to go that direction as well. A 250-300 shot of NoS or about 6-8lbs of boost would not hurt this beast at all.
Im selling it as a complete package, WITH THE FiTech EFI, Coil, 6qts of fresh oil w/new filter. Ready to rock and roll. With a pan full of fresh Synthetic oil, it should pick up 7-10hp and it will make more power as things settle in and the EFI learns more. SO 600HP is a very real result with this 408.
Complete, all forged internals, dyno run and base tuned, 408 w/EFI for $11,000 OBO
Located in Michigan
It can also be seen on MRL Performance facebook page for pics and videos.
Thanks for looking. PM me if interested.
I'm willing to deal on this. I need to get this to a good home. I will consider any reasonable offers. This us one hell of a good small block stroker. Someone out there is going to get the deal of the year.
Start the new year off with a great new power plant in your ride.
EFI, full forged internals, fully pored heads, 5qt Kevko pan, solid roller cam, Comp Pro Magnum rockers with a life time warranty, all the good stuff. Over $9000 in parts alone. Professionally built. You can not loose with this beast.
Lets make a deal. Make 2017 your year for Mopar fun.
Spring will be here before you know it. Hit the streets Running with this Nasty Little Beast. Hook it up and GO! Your not going to get a better deal this year, 580+HP small block, with EFI ready to go.
