MSD 5300 for a mopar
Jmcginnis89
Missouri
This is a bit old but should it work on my slant and work good or did I wast my money ?
i dont know what it is but thru MSD someone asked if it will work on there 73 dart with electronic ignition and MSD said it plugs right in. hopes this helps!
P.S. im i correct to assume its a ECU from MSD?
I used to have an msd box with the mopar electronic ignition plug on it. Mine was toast though
Here..
I have one of those it is an MSD-5C box or somethin like that
But it has the plug on it so you dont have to cut up a harness or splice wires and plug directly in place of the electronic ignition box
I plan to install mine on my Duster or put it on the Charger because I just love the vintage look of it
I should have it this week I I should be in the mail the I can post a pic of the plug
I haven't got it yet its still in the mail I'm going to use it on my slant build doing
Yup - I have a 5C on my plow truck. uses the stock module connector to plug in.
On the other end of this msd box there is a sort of plug anyone know what's suppose to hook in there
