[FOR SALE] MSD 6al2 Programmable ignition box with 2 step and rev limiter
67charger383
Maryland
Rating - 0%
0   0   0
For sale is a like new condition MSD 6al2 Programmable ignition box including the MSD harness.
This is a fully computer programmable ignition box that includes 2 step and a rev limiter
I bought this for a project and ended up going with an entirely different ignition setup.
These retail for $600 I am asking $300 plus shipping or pickup in Boyds, MD
From MSD's website:
"The Programmable 6AL-2 lets you lock out the distributor and program a timing curve via a PC. You'll also be able to set a 2-Step Rev Limiter, a retard for use with nitrous and even a boost timing curve for forced induction engines! The Programmable 6AL-2 shares the same advanced features of the new 6AL-2 with 535 primary volts and spark energy reaching 135 mJ! Vibration mounts, wiring and a PC cable are supplied. Must use MSD Pro-Data+ Software to program.
Features:​
  • Advanced features allow for use in street and racing applications
  • PC Programmable with easy-to-use Windows based Pro-Data +Software
  • Plot a boost timing map with 0.1° per psi accuracy
  • Programmable 3-Step Rev Limiter (100 RPM increments)
  • Step retard for nitrous applications plus a boost timing map
  • Capacitive Discharge technology for fast rise time and maximum spark energy
  • EO # D-115-21"
