hellfirechrome
Hey folks! Have a good deal on a darn expensive dizzy. Powers my 378ci Small Block extremely well! I can't use this with my blower setup (FITech can only control their simpler 2-wire distributor for timing retard under boost) so I'm selling this to get the basic MSD dizzy, and now someone else's ride will be blasting off! Well over $100 off MSRP, includes original box and necessary wires. Video available on request!
Seriously, 3 wires (no box!) and 5 minutes and this thing was firing my engine better than any other system I have used; that's why I'm sticking with MSD.
I'm looking for $325 plus $20 to ship (from Rodeo, Ca.) to anywhere in the continental US. It's listed on my Ebay for more, but you guys are great so here it is!
CHRYSLER 318-360, READY-TO-RUN DISTRIBUTOR
Fits 273, 318, 340 and 360 small block Chryslers. Ready-to-run distributors include a built-in ignition module. No MSD Ignition control required. Includes a built-in rev limiter
PART# 8388
$463.95 Suggested Retail
MSD’s Ready-to-Run Pro-Billet Distributors for Chrysler engines are the perfect upgrade from breaker points or weak electronic ignitions. These distributors feature a maintenance-free magnetic pick-up that accurately triggers the built-in powerful ignition module. This module produces a high-output spark which improves combustion in the cylinder, resulting in quick starts, a smooth idle and great performance. Just beneath the race rotor is a mechanical advance assembly so a timing curve can easily be tailored to match your application. The QPQcoated shaft is guided by a sealed ball bearing assembly for stability and endurance while a vacuum advance canister helps increase economy on those long cruises. The Ready-to-Run Distributors are also a breeze to install. Simply drop it in the engine and connect three wires and you’re ready-to-run to your favorite cruise! The front engine mount models are designed in a special small diameter housing to clear aftermarket heads and valve covers.
Features:
The following vehicles are considered Emissions Controlled Vehicles:
Here's what MSD says about the 8388:
PART# 8388
Features:
- Simple and clean installation with only three wires to connect
- Mechanical advance assembly can be locked out for crank trigger systems
- Supplied with a HEI style distributor cap and rotor (accepts Cap-A-Dapts)
- CARB E.O. Approved
- Advance plate and weights are fine blanked from chrome moly steel and QPQ coated for friction reduction
- Polished steel shaft is QPQ coated and guided by sealed ball bearings
- Maintenance-free magnetic pickup and precision reluctor create stable trigger signals throughout the rpm range
- Vacuum advance canister for improved economy (can be locked out)
- Easy-to-adjust mechanical advance with supplied springs and stop bushings
- Powerful built-in module produces a 7.5 amp single spark through high rpm
- Now includes built-in Rev Limiter
- 1966 and newer U.S. manufactured California Certified vehicles
- 1968 and newer U.S. manufactured Federally Certified vehicles
- 1968 and newer Foreign manufactured vehicle
