MSD Coil on plugs vs Factory OEM
Rat Patrol
On the outskirts
Has anyone done a back to back trial - detected any difference in gas mileage, running temp, peformance or smoothness of idle?
They would have to make alot of difference to justify 400 plus dollars.
My truck has original coils, so I cant answer the question, just an opinion
No need to change coils as the factory one's work quite well.
Don't waste your money.
This is pure speculation based upon my understanding and research into coil on plug technology, and not from first hand experience.
If we look at a traditional ignition system we have a single coil firing 8 cylinders. At 6000 RPM the coil has to fire 3000 times per minute per cylinder for a total 24,000 times per minute or 400 times per second. As a dwell times (the time the coil has to charge before firing again) fall to .0025 of a second the quality of the coil becomes more important. Further, traditional coils only operate at 9 volts!
The modern hemi utilizes a coil on plug arrangement in which each coil only fires a single cylinder (or in wasted spark two cylinders). At 6000 RPM a coil only has to fire 3000 to 6000 times per minute vs 24,000 times. Thus, the amount of dwell time available increase from .0025 seconds to .02 seconds. Even in wasted spark mode the coil has four times the available dwell times.
To put this all in perspective hot rod did a test with a supercharger / turbo charged Chevy LS motor with 20 Lbs of boost. Only when the motor went over 20 lbs of boost did they start to run into problems with the stock LS coils.
Also the guys at megasquirt did some testing on the LS style coils and found them to be flame throwers. Very powerful, and very cheap.
I'd consider the Hemi coils to be similar in power output to the LS coils. Hotrod has done several hemi engine tests with between 500 and 1000 HP and has always used stock coils.
Unless you are running extremely high boost (over 20 lbs) or a ridiculous amount of NOS, I'd spend your money elsewhere, for example, you could donate the money to the joe-dokes let's finish this hemi project fund. ;)
Best of Luck
Regards,
Joe Dokes
Well Joe -I put the msd coils on my 5.7 I guess that makes me a dummy!!!!!
Cevidicus,
Thanks for the article. I'm a touch skeptical though. The article claimed that the Granatelli provided 10 additional HP, a smoother idle, and more consistent ets. I know there are a lot of games people can play with dynos, you'll notice that the testing took place on a Granatelli dyno. Yet, they didn't bother to show a list of time slips with these consistent ETs.
I'd like to see some independent test results.
I do think Granatelli coils and their hotter spark might be useful on the supercharged or NOS applications, which upon further investigation it is clear that they installed the Granatelli coils on a 6.1L Hemi with a Magnuson supercharger.
I'd like to see these tested on a stock motor.
Regards,
Joe Dokes
Even if they do work on a stock motor, $600 for 11hp doesn't seam worth it...
Seems to be no different story to what I learned in "old school" -
For most pump gas cars......there's more benefit in a decent ignition curve than there is in having a spark like an Arc Welder.
Seriously people, we have a car with 15 pounds of boost and a 200 shot running stock coils. Stock coils are not a limiting factor in any way
