[SOLD] MSD Digital 6 Plus Ignition Box – Used
Rocket
CT
For sale is a used MSD Digital 6 Plus ignition box. I used this on my Dart bracket car a number of years ago. Worked well. I used an MSD blaster 3 coil along with this box. Rev limits and other settings are easy to set with the dials on the end of the unit.
Note two wires were cut and can be seen in the photo. I do not believe these were needed with my set up Lengths of wire can be soldered on if needed. Installation instructions are available on MSD's website.
Here is some additional information and specs on the unit.
Ignition Box Output: Capacitive discharge
Circuitry: Digital
Rev Limiter: Yes
Timing Retard: One-stage
Data Acquisition: No
CD Voltage Output to Coil: 535 V
Current Draw: 7.4 amps at 10,000 rpm
Spark Output (millijoules): 135 Millijoules
Minimum Operating Voltage: 7 V
Maximum Operating Voltage: 18 V
Length (in): 8.500 in.
Height (in): 2.250 in.
Width (in): 4.500 in.
MSD has combined race-winning experience with leading-edge technology to offer these incredible Digital-6 Plus ignitions. The 15 MHz micro-controller can analyze up to 15,000,000 critical instructions per second! That's over three times faster than comparable ignitions. Every spark is packed with 135 millijoules of spark energy and 535 V of power. Built-in features on the MSD Digital-6 Plus ignition include two rotary switch adjustable rev limiters, a single-stage timing retard, a start-up timing retard, an LED fault display, EMI protection, and much more! You get complete combustion for greater power, quicker throttle response, smoother idling, and quicker starts. You always get more power with less current draw.
Price is $220 shipped in the lower 48 states.
PM me with any questions.
Superbeesrt8 please empty your inbox and I will send you my PayPal info.
Thanks
