MSD Distributor
moparstud440
Keymar, MD
Looking to upgrade to a MSD 8534 distributor. I already have MSD 8 mm wires on my car, but they have the stock Female ends. Does a stock cap work on a MSD distributor or can you buy a cap to accept the female ends?
Don't know about the cap but why not switch the ends to HEI? You can do so with little to none length loss and in my opinion the HEI setup is a lot nicer.
The caps I use on my MSD distributor are MSD’s GM replacement cap with the door in the side. It’ll use the wires you already have.
