Orionsax7
Headlights flicker after installing MSD 6A on 71 demon. In fact whole system jumps from 13 to 14 volt with RPM. Any ideas why?
-Alex
-Alex
Did you ever find the solution to this? I have the exact same problem on my 74 Dart. ThanksHeadlights flicker after installing MSD 6A on 71 demon. In fact whole system jumps from 13 to 14 volt with RPM. Any ideas why?
-Alex
Thanks will check that out.It might be that the high energy spark of the MSD is causing interference into the charging system. Make sure regulator / field wiring is routed as close to ground as possible, and away from spark plug wires.
