[FOR SALE] MSD Soft Touch Rev Control #8728 Points/Electronic Ignition
goldduster318
Overzealous Car Modifier
Lake Orion, MI
MSD Soft Touch Rev Control #8728 + 5000 RPM Pill set. This will work with the factory electronic ignition and is currently set up this way. Pigtail has weatherpack connector (both sides). Simply connect power, ground, and both sides of the coil and it will cut spark at the limit set by the pill. Worked well.
$75+Shipping
