MSD Tach Adapter 8920, Autometer Shift Light
billytuffnuts
Newport Beach, CA
Have a used MSD Tach Adaptor, Part # 8920. If you've recently installed a MSD or similar ignition box and your tach stopped working, you may need this adapter for it to work. I bought this used myself and ended up not using it so I've never actually tested it. It has two small pieces missing out of the case where it looks like someone tried to remove the cover to repair one of the wires. Sold as is
$20
Also have a used autometer shift light. Amber lense, yellow lens cover. I believe the part # is 5334 $25
