[FOR SALE] Multiple Mech. Items - mopar only
swing69
fightin' socialism
Central Socialist NJ
I will update this first post often. Add stuff, update status. Here is the list and the prices. Lots of other small stuff...so ask. All parts in Central NJ. PU preferred, shipping on your dime.
1) Engine Stuff:
- - 360 KIT: recently rebuilt 360 engine bottom end (assembled). Newly rebuilt heads 596 (new valves and guides - plugged pump holes). New timing set with tensioner, new 360 A body Mildon pan. New Summit 1601 cam. $900 obo. all parts clean, repainted chrysler red.
- - 360 core block and crank. (74?) $150 obo (no pict)
- - used, but clean and repainted Spitfires for SB - - Sale Pending 4-17
- - Mopar big block waterpump housing, left side inlet cast iron OEM (1969?) $90
- - recenty rebuilt, very low use 906 heads, with rockers and shaft $350
- - blasted, coated OEM early a v8 exh. manifolds $125 for the pair.
2) INTAKE Stuff:
- - SB Performer RPM painted red (very good condition). $150 firm.
- - Wieand Torker 2, 1 weld repair, $75
- - Chevy sb sp2 $40
3) Drive line:
- - Clean / good used, repainted 904 lockup trans with lockupTC $350 from a 5th ave
- - SB 727 to bolt up to 360. used, clean, good condition, new paint $250
- - multiple clean OEM torque converters.....painted. $35 each
- - REAR KIT
all parts CLEAN and Primed or painted. A-body 8.75 Housing, 3.23 742 rear (open), NEW LBP axles w bearings (in box from Cass), Backing plates and hardware for 10x2.5" rear brakes. $900 the rear kit.
4) Interior:
- - 69 shifter and console for SB auto. with linkage. silver p-coated top plate. Also have OEM 69 tunnel section with console brackets. $500. (see picts
- - Left side 1/2 floor pan (AMD) new in box. $150
- - Black kickpanels and steering cover $30
- - Steering wheels: 68 b body 3 spoke, $150....76 Dart black, no cracks $40, all other $75.
- - B & M small block shifter $100 complete with cable, housing "trimmed" to hump contour.
5) Bright stuff:
- - Nice 64 Dart Grille $75
- - several sets of front windshield surround trim. 70's 2 dr. gotta check closer. You'll need to inspect in person to see if this is the right trim for you. some years differ!
- - 1 rear set; $75 dart concave rear glass type. I think they are all the same.
6) Chassis Stuff
- - good manual steering box for A body. clean - painted $80 I think I have 2 available.
- - 2 nice machined OEM 73+ rotors. $60 for the pair.
- - 2 new rotors, in the box. Aimco? (asian made) $75 for the pair.
- - FJM spindles, blasted painted. $90
- - welded LCA with pins for coil over set up. A body $75
PM if interest.
picts
more
more picts
more and more....... don't see something....ask.
Are the spitfire headers for the early A bodies? How did they fit? Thanks
"Mopar big block waterpump housing, left side inlet $90"
Is the housing Cast Iron?
Tks
just checked. both MS boxes are standard ratio. no quick ratios.
how much shipped to sun prairie wi. 53590 for the headers and do they come with proper size bolts and instructions for the slide bolt holes , I can see they were bent but were they twisted?? pay pal address dam that's a lot of fee's, another $13.50%on top . wow first guy tells me this car isn't worth 22,500.00 will get hit hard with receipts and arm cramps from writing checks and cranking nuts and bolts holler 1 608 837 4427 jon fri morning 8;00 sharp if you can thanks JON 53590/zip code
Headers are spoken for. There is no hardware. studs on the ends, bolts on the rest. No, they are not twisted, dinged for clearance for the column and eddy heads.
There were sealing and working fine when replaced by TTIs.
Can't update the orig.post. Here is the update.
The 360 and 8.75 will be built up by me for a future project. BB heads are still for sale. fender shields sold. spitfires sold. waterpump housing sold.
