My 273 curved dist with pertronix ign III
stroker402
1968 dart GTS convertible
milwaukee wi.
Just recurved my dist for my 65 formula S 273
The recipe is :
Fbo plate :
14* mechanical
20* initial
light springs
pertronix ignitor III with rev limiter.
ignitor coil
rev limit Set at 6400 rpm.
vac adv arm 9.5 probally won't hook up to vac source .
Should ROCK !
Similar set-up I had in a commando 273 car years ago . worked Great !
Do you know at what rpm you will be at to get the full 14 degrees mechanical advance?
I haven't installed the dist yet . I'll see where the numbers are when I get it running . I can always make changes to what it likes.
too cold to be wrenching here today .
I think we are getting dumped on again , here in S E Wis today, also John.
Nice distributer, I might have to copy it for my 66 B-Cuda
Dave
