My 318 stroker update... engine is done
Small Block Mopar Engine
  1. cawcislo
    cawcislo Well-Known Member
    297
    193
    Aug 7, 2018
    Ontario, Canada
    Local Time:
    1:25 PM
    So I started a thread this spring regarding. Doing a mean 318 rebuild or go for a 328 stroker. Here’s the thread...
    Mean 318...or stroker....hmmm
    I took my time and did it all myself and so far so good. It’s now running so I’m on to the tuning stage.
    the specs... 1977 318 block, bored 40 over so technically we have a 392. Scat kit which came with cast crank scat forged I beam rods, icon forged step dished pistons (23 cc dish). Went with 0.005 clearance on pistons to cylinder wall and went with 0.020 ring end gap on top ring and 0.022 on the second rings.
    block was align honed, and I went with ARP main studs. I went with a kevko 6 quart pan with kick outs which needed the front passenger corner trimmed up as well as a notch in the k frame for clearance. I posted some pics in another thread.
    I did a few of the oil mods (like drilling out certain oil passages to 1/2 inch, adding extra holes to the oil filter base plate, and Doing a bit of work on the milling high volume pump. You can refer to the guitar Jones oil mods if you want to see what his mods were although he want all the way and I just did some of the basics.
    block was decked and only needed 0.010 on one side and 0.005 on the other to get me to zero deck. For stage one of my build with my reused mildly ported 360 iron heads with overuse valves and 64 cc chambers I will have 9.4:1 compression. I checked the heads and replaced the valve seals and lapped the valves just to give it a bit of a refresh. I also reused my Crower 224/224 .465 loft cam.
    Howard’s cams billet double roller timing chain and a fluidampr were added. I reused the Weiand action plus intake, 750 vac secondary carb and Doug headers.
    I assembled everything and mocked it up on the engine stand so I could get a nic visual of the completed product. It fired right up every seems good and I took it for a few spins.
    future plans for stage two include aluminum heads, Edelbrock air gap intake, and a bigger cam. For now she’ll do as is. Along the way I had som questions and this forum cam through so thanks boys. Happy hot rodding.
    • Like Like x 5
    • 69conv
      69conv error 401 FABO Gold Member
      3,449
      4729
      Jan 27, 2013
      Motor City
      Local Time:
      12:25 PM
      Lets hear it run!!!!!!!!!!!!!!!!!!!!!
      • Agree Agree x 4
      • cawcislo
        297
        193
        Aug 7, 2018
        Ontario, Canada
        Local Time:
        1:25 PM
        Here some pics.
        • Like Like x 10
        • cawcislo
          297
          193
          Aug 7, 2018
          Ontario, Canada
          Local Time:
          1:25 PM
          are you saying you don’t believe me that it runs.... lol. I’ll take a video tomorrow and post it.
        • toolmanmike
          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
          52,967
          38459
          Jan 18, 2006
          Iowa
          Local Time:
          12:25 PM
          Looks great!
          • Agree Agree x 2
          • 69conv
            3,449
            4729
            Jan 27, 2013
            Motor City
            Local Time:
            12:25 PM
            Naw, I just love the sound of a healthy motor! I know how I felt when I fired up my new build.
            • Agree Agree x 3
            • mygasser
              mygasser FABO Gold Member FABO Gold Member
              668
              364
              Aug 17, 2010
              faversham, kent. united kingdom
              Local Time:
              12:25 PM
              are you thru the first set of rear tyres yet? :lol:
              neil.
            • SSG_Karg
              SSG_Karg Heeeeeres Johnny!
              1,352
              1214
              Feb 24, 2010
              In the pits
              Local Time:
              1:25 PM
              How much was the stroker kit and who did you buy it from?
            • 318willrun
              318willrun Utube channel 318willrun
              15,501
              16628
              Sep 13, 2013
              I'm here
              Local Time:
              12:25 PM
              Nice!
            • cawcislo
              297
              193
              Aug 7, 2018
              Ontario, Canada
              Local Time:
              1:25 PM
              $1423 for the scat kit which includes, Scat cast crank which was balanced For this kit, forged scat I beam rods, forged icon pistons, Hastings piston rings, clevite 77 main bearings, clevite rod bearings. It came from summit racing.
              • Like Like x 1
              • Thanks! Thanks! x 1
              • cawcislo
                297
                193
                Aug 7, 2018
                Ontario, Canada
                Local Time:
                1:25 PM
                My stage one build is pretty mild, so not tearing it up too much yet. I also have a stock type used clutch which probably wouldn’t be up to the task if I were too abusive to it.
                • Like Like x 1
                • Nat
                  Nat Well-Known Member
                  409
                  219
                  Jun 11, 2019
                  Netherland
                  Local Time:
                  5:25 PM
                  sure don'tsound like a mild build . Good luck and get some sound clips and videos up
                  • Like Like x 1
                  • Agree Agree x 1
