1. dartfreak75
    dartfreak75 Restore it, Dont part it! FABO Gold Member
    8,358
    5860
    Aug 10, 2011
    Virginia
    Local Time:
    12:33 AM
    I want to start a thread documenting my progress on my 360 build. For the ones that dont follow my car build thread this engine is going into a 1975 dart swinger that I'm slowly building. The engine is a 1977 360 the block was machined. 060 over I'm using kb107 pistons on the stock rods and a refurbished stock crank and stock harmonic balancer. The cam is a lunati voodoo 262/286 duration .475/.495 lift. I'm using matching lunati microtrol lifters. The heads are the factory 360 heads that I ported myself I didn't go to wild on them. I cut the guides for positive seals and had a valve job done. The valves are the factory 1.88 size and are all new melling valves the exhaust valves are also factory with engine tech valves. The heads where shaved .030 to ensure they are flat. The head cc came out around 63 after they were milled. The compression should be around 10.2. Up top I have a factory 1971 (I believe) 340 intake and a fresh thermoquad carb. The TQ is the large main 1 1/2 primary carb. I am gonna be posting alot of pictures so enjoy. Feel free to give me any tips or tricks or construction criticism. This is my first full rebuild and I'm learning.
    • Like Like x 6
    • rumblefish360
      rumblefish360 So close, yet so far away FABO Gold Member
      39,015
      10591
      Jun 21, 2005
      New York, on a Island
      Local Time:
      12:33 AM
      Go for it! Looking forward to it.
      • Agree Agree x 1
      • Mopar Sam
        Mopar Sam Well Fed Member
        1,212
        1705
        Jul 18, 2008
        Indiana
        Local Time:
        12:33 AM
        Sounds FUN!
        • Like Like x 1
        • Agree Agree x 1
        • dartfreak75
          8,358
          5860
          Aug 10, 2011
          Virginia
          Local Time:
          12:33 AM
          Ok so here goes. What iv got done so far is the machine work. Boring the block milling the heads and the valve job. I cleaned out the extra metal In the valley with a dremal cleaned it really good gave it an oil bath and got the plugs put in it. I got the cam bearing installed. I had to shave them using the old cam I took a cutoff wheel and cut diagonal slots in the journals and turned it with a wrench. Now the new cam fits great in the new bearings. The only oil mod I did was drill a small hole in the front oil plug and one in the cam thrust plate to let some oil squirt onto the timing chain. I may go back and drill four holes into the oil filter plate. I put the block to the side and started in the heads I started measuring my valve spring installed height and i have ran into problems there they are considerably shorter than they are "suppose" to be they are coming in at around 1.62 the shorted is 1.605 the tallest is 1.64 on the intake side and the exhaust is 1.62-1.65 the problem here is my valve springs have a coil bind of 1.1 so doing the math that only leaves me about .026 on the shortest exhaust side. So I'm either gonna have to cut the seats all to 1.65 or find new springs.
          • Like Like x 5
          • jay27
            jay27 Active Member
            39
            19
            Dec 31, 2011
            Saskatchewan
            Local Time:
            10:33 PM
            I like your build and the stock look , it will run very well. I like the factory intake and T/Q. This is the engine in my garbage truck , i did not have a stock intake but had an LD340 , here is a pic of mine 20161010_214012.jpg
            • Like Like x 7
            • dartfreak75
              8,358
              5860
              Aug 10, 2011
              Virginia
              Local Time:
              12:33 AM
              Thanks that looks really good. That's the look I'm going for I want it to look completely stock but run a little better than stock. I know in 1975 the 360s where pretty weak due to emissions and low compression. I wish I could find a correct set of 75 valve overs the ones I have are off a 69 340. Most ppl will never tell a difference and the ppl who can will probably just think it's a 340 engine lol i like the original appearance I have also decided to go with exhaust manifolds instead of headers just to keep the original look going. I bought a super nice snorkel air cleaner off of a member here it's a 2bbl cleaner but I am gonna try and modify the bottom to fit a 4 bbl that's gonna be a later project but I'm gonna buy just the bottom of a 4bbl cleaner and cut weld and fab it into the bottom of the 2bbl cleaner.
              • Like Like x 1
              • dartfreak75
                8,358
                5860
                Aug 10, 2011
                Virginia
                Local Time:
                12:33 AM
                More pics
                • Like Like x 3
                • jay27
                  jay27 Active Member
                  39
                  19
                  Dec 31, 2011
                  Saskatchewan
                  Local Time:
                  10:33 PM
                  Thanks , If I find any mid 70s covers I will let you know , looks good. What are those manifolds?
                  • Thanks! Thanks! x 1
                  • rumblefish360
                    39,015
                    10591
                    Jun 21, 2005
                    Local Time:
                    12:33 AM
                    Magnum manifolds.
                    • Agree Agree x 1
                    • jay27
                      jay27 Active Member
                      39
                      19
                      Dec 31, 2011
                      Saskatchewan
                      Local Time:
                      10:33 PM
                      Oh right , never used any before but people have said they are decent. Thanks.
                      • Like Like x 1
                      • dartfreak75
                        8,358
                        5860
                        Aug 10, 2011
                        Virginia
                        Local Time:
                        12:33 AM
                        Yep rumbles correct magnums idk how they are gonna fit yet but I'm gonna give it a whirl I have a pair of the crappy 80s headers that everyone hates if they dont fit right. I'm hoping they will it will fit the "original" look I'm going for without spending 500 on 340 manifolds. I got those locally for 35 bucks.
                        • Like Like x 1
                        • moparmandan
                          moparmandan FABO Gold Member FABO Gold Member
                          2,529
                          2351
                          Jun 28, 2017
                          Deland, FL
                          Local Time:
                          12:33 AM
                          Looking good man!
                          • dartfreak75
                            8,358
                            5860
                            Aug 10, 2011
                            Virginia
                            Local Time:
                            12:33 AM
                            I decided to re measure the spring height and I wrote them all down in order and marked the heads so I can remember exactly what each one of them was. Here are the numbers I got. Now I just gotta do the math on my coil bind and spring pressure and decide what I'm gonna do. Head one looks pretty good head 2 is concerning.
                            Head 1
                            Ex 1.65
                            In 1.635
                            In 1.635
                            Ex 1.65
                            Ex 1.655
                            In 1.64
                            In 1.64
                            Ex 1.655
                            Head 2
                            Ex 1.65
                            In 1.61
                            In 1.635
                            Ex 1.635
                            Ex1.64
                            In 1.615
                            In 1.62
                            Ex 1.655
                          • 67/6barracuda
                            67/6barracuda Well-Known Member
                            726
                            779
                            Jun 24, 2013
                            Sharpsburg, GA
                            Local Time:
                            11:33 PM
                            I think you are well within spec there brother. If you where 1.5 or 1.7 range then yeah I would be concerned. I would run it as is or shims work too if looking to get it dead nuts on. Plus or minus .020 no big deal
                            • RustyRatRod
                              RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                              64,431
                              37378
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              12:33 AM
                              Comin along!
                              • dartfreak75
                                8,358
                                5860
                                Aug 10, 2011
                                Virginia
                                Local Time:
                                12:33 AM
                                The problem is its short and not long. If they where a but over id shim them but shorter cant really be shimmed.
                              • RAT ROD AL
                                RAT ROD AL I know just enough to be dangerous FABO Gold Member
                                3,851
                                4416
                                Jan 18, 2013
                                St. James City. FL.
                                Local Time:
                                12:33 AM
                                I tried a pair of those manifolds. RT side would fit nice with no interference , left wouldn't work because I have a 4 spd and the Z bar was in the way . Might work on an automatic. Good luck. Lookin Good !
                                • dartfreak75
                                  8,358
                                  5860
                                  Aug 10, 2011
                                  Virginia
                                  Local Time:
                                  12:33 AM
                                  Ok so i did all the math and to keep the coil bind over .050 the intake install height has to be at least 1.625 and the exhaust side has to be at least 1.645
                                • dartfreak75
                                  8,358
                                  5860
                                  Aug 10, 2011
                                  Virginia
                                  Local Time:
                                  12:33 AM
                                  Yea i have an automatic and i converted it to a floor shift so all the linkages have been removed. My biggest concern is steering column. We will see what happens lol
                                  • Agree Agree x 1
                                  • RAT ROD AL
                                    3,851
                                    4416
                                    Jan 18, 2013
                                    St. James City. FL.
                                    Local Time:
                                    12:33 AM
                                    You might be OK . I don't remember my steering shaft being the problem
                                    • dartfreak75
                                      8,358
                                      5860
                                      Aug 10, 2011
                                      Virginia
                                      Local Time:
                                      12:33 AM
                                      I hope so im excited about them .
                                    • RAT ROD AL
                                      3,851
                                      4416
                                      Jan 18, 2013
                                      St. James City. FL.
                                      Local Time:
                                      12:33 AM
                                      They look like they would flow well.
                                    • dartfreak75
                                      8,358
                                      5860
                                      Aug 10, 2011
                                      Virginia
                                      Local Time:
                                      12:33 AM
                                      From what iv read they flow similar to the 340 ones. I know headers will out flow them but im willing to give up 10-15 hp for a better looking user friendly package. I dont want to scrape every speed bump and have the headaches of changing plugs and melted wires. I know alot will disagree with me.
                                      • Like Like x 1
                                      • Agree Agree x 1
                                      • 318willrun
                                        318willrun Utube channel 318willrun
                                        15,472
                                        16588
                                        Sep 13, 2013
                                        I'm here
                                        Local Time:
                                        11:33 PM
                                        Very nice parts selection!! Let me tell you, once that carb is set up right, and you've got the timing right, you'll have stomp like you've never dreamed! STart saving now for DOT drag radials, cause you gonna need 'em!!!!!!
                                        • Like Like x 2
                                        • Agree Agree x 1
                                        • dartfreak75
                                          8,358
                                          5860
                                          Aug 10, 2011
                                          Virginia
                                          Local Time:
                                          12:33 AM
                                          Its funny you mentioned tires because i have been doing a lot of research on them the last few days. I may end up moving the springs in later. I have to replace the leaf springs eventually when I do I may move them inward depending on how much traction issues I have. I measured and about the widest I can go now is 235s I think if I can get the tuning down its gonna be a strong engine. I forgot to mention the rest of the combo. I got a neutral balance flywheel and a boss hog converter it's their street series it's like a 2200 stall I believe. And a 999 torqueflight with 3.73 rear gears
