captain america
Here is my 470 build that I am just about to finish up.
470 Stroker engine
400 Block
Aluminum main caps with studs
440 steel cranked stroked
3.915 Stroke
4.375 Bore
Ross Pistons Dome C.H. 1.633
Eagle Rods
Bullet solid roller Cam .681 lift 280 duration @ .050
Milodon oil system
Comp lifters and springs
Smith Brothers push rods
Harland Sharps 1.5 roller rockers
452 heads fully ported polished and bowl work
M1 intake
Holly 800 carburetor (for now? any suggestions)
Msd ignition
TTI headers
Electric fan
727 transmission
B&M Trans cooler
Turbo Action forward manual valve body
Turbo Action Cheetah shifter
8 ¾ rear
4.10 gear
Yukon axles Wildwood brakes
255/60 Mickey Thompson ET Street Radial ( For now will mini tub later)Super Stock leaf springs
Let me know what you think of the build. What do you think it will run? and any suggestions on the carb? I was thinking mabe a Chuck Nuytten.
470 Stroker engine
400 Block
3.915 Stroke
4.375 Bore
Eagle Rods
Milodon oil system
M1 intake
Msd ignition
TTI headers
Electric fan
727 transmission
B&M Trans cooler
8 ¾ rear
4.10 gear
