standup303
Have really been wanting to take the time to document my progress on my 69 Dart Custom. So here it goes….
Purchased the car May 6 2023 in Meeker, OK. Trailered it back to Castle Rock, CO. Original setup is:
69 Dart Custom 273, 727 car, bench seat
Purchased as 360LA, 727, 8 3/4 with 4.10s, long tube headers, flowmaster 40s, QA1 upper and lower control arms, QA1 adjustable shocks, Wilwood discs up front, aftermarket gauges/console, CVF serpentine system, AVS 650cfm carb
First thing I did was rebuild the steering column as it was very loose. Replaced the coupler and installed a bearing from Bergman Auto Craft. Tightened things up nicely.
The car had a driveline vibration, which I remember being pissed I didn’t notice more on the test drive. I dropped the trans, replaced the neutral balance converter and flex plate with a B&M external balance flex plate and neutral Balance Hughes 2500 converter. Huge improvement.
