ValerianMagnum
the little car that could
hi guys i was wondering what was the weight of my 74 cuda ...
its originally a 318 car but now swapped to a 340, 0.30 over roller engine
-69 Cuda 340 cubic inch engine
- Oversized 0.30 now 345 c.i.
- Balanced engine ..builted by Nick Amenti
- Forged mopar performance crankshaft
- Comp camps timing set
- Comp cams double renforced valve springs
- Comp cams hi-tech pushrods
- Comp cams lifters
- Comp cams roller rockers 1.6 rocker arms
- Mopar performances oil pan
- Ported x heads 2.02 -1.60 modified valves
- All roller engine
- Modified 750 cfm holley carburator , choke trottle removed
- Intake Holley single plane W2 porter stage 2
- Pistons ROSS hypertetique
- Full Mr.Gasket gasket kit
- Chiped msd-6Al @ 6 200 rpm
- Camshaft comp cam ..magnum hi-perf series
-292 duration and 501 lift cam ( comp-cam )
- MSD Ignition kit
- Distributor MSD
- Coil MSD
- Fillage taylor 8.0
- March one full set pulleys
- NGK Platinum spark plugs
- Billet special air bowl
- Billet special polished oil cap
- CENTERFORCE dual friction clutch
- Earls hi-perf fuel lines
- Holley hp fuel pump
- Holley brand flowtech polished headers
- Mopar electric fan
- OPTIMA red battery relocated in the rear
-Renforced rear and front frame rails
-3.23 ratio suregrip rear-end
-Tranny A-833 4 speed Standard -custom buit shifter rods
-Moroso air shocks suspension rear
-Lowered stock coponents in the front with disc brakes
i was saying :
400 hp / 400 torque
3 400 pounds
and 13.5 quarter miles ???
- Comp cams lifters
- All roller engine
- MSD Ignition kit
- Distributor MSD
- Coil MSD
i was saying :
400 hp / 400 torque
3 400 pounds
